ASA/IPS licensing
Feb 12th, 2008
I'm using ASA with SSM-10 module for IPS.
When trying to access with ASDM to the IPS it tells me that there is no license included, unless that the IPS works normaly. and also when checking for IPS licenses I found nothing.
They told be that I need a SUSA license to buy?
I need it really ??
doering Tue, 02/12/2008 - 14:29
Hello Omar;
If you use your ASDM gui and go to 'Configuration > IPS > Licensing
You will see the 'Current License' and the 'License Status', Expiration Date and Serial Number.
If you have not licensed the IPS. You will be limited in your ability to provide IPS services past the 'trial key' that comes with the device.
