Remote accesss vpn with LDAP microsoft active directory integration
Feb 12th, 2008
Dear Netpros,
I need your help on the below deisgn to work with remote access vpn with LDAP for both auth and authrorization.
The ASA 5520 is located behind the internet router. The ASA act as vpn gateway. I used the ASDM to configure the
remote access vpn with LDAP authentication and authrorization. the ASA firewall inside connected to the sidewider FW outside segement and the sidewider internal goes to local LAN (
I created the pool for the remote users in the ASA with range that is in between ASA in-sidewinder out segemt.No tunnel established but getting authenticaion failure.
Please tell me what are thesteps needed in ASA and inside LDAP server and the sidewinder firewall to configure to finish the vpn setup
