02-12-2008 06:53 AM - edited 03-15-2019 08:47 AM
Guys,
I need clarification on this issue. I have seen here Cderen and gogasca have pointed out that this cannot be done even during DMA restore..
Here is an excerpt from a documentation from cisco on this issue.
"Cisco Unified CallManager Installation
Cisco Unified CallManager 5.1 includes the following installation enhancements.
⢠New network connectivity checking-The installation program checks for network connectivity. If
the network is not accessible, several options exist for how to proceed with the installation.
⢠New hostname and IP assignment during upgrade-The upgrade installation program now allows
you to use a different hostname or IP address on the upgraded system.
For more information
⢠Installing Cisco Unified CallManager Release 5.1(1)
⢠Upgrading Cisco Unified CallManager Release 5.1(1)
Data Migration Assistant (DMA) 5.1 includes the following enhancements:
⢠DMA migrates data for upgrades of Cisco Emergency Responder (CER) 1.3.
⢠Enhanced interaction between DMA and Cisco Security Agent for Cisco Unified CallManager
(CSA) occurs. Depending on the versions of DMA and CSA that you are using, you may possibly
leave CSA enabled while DMA runs. In other cases, DMA automatically disables CSA while it is
running, and, in some cases, you must disable CSA manually while you are running DMA.
⢠Data Migration Assistant User Guide Release 5.1(1)"
Attached is the documentation...
Please I need clarification on this...
Is this possible or not
Solved! Go to Solution.
02-12-2008 07:27 AM
Hi Deji,
Hope all is well :)
Just be careful of the note from Gonz highlighted below;
Assigning the Host Name/IP Address (Servername) to the 5.1(1) Server
In 4.x releases, the Host Name/IP Address field (also known as Servername) on the publisher server Server Configuration Settings window contains one of the following types of values:
â¢If DNS is enabled, it identifies the host name.
â¢If DNS is not enabled, it contains the IP address of the server.
To access Server Configuration Settings, navigate to System > Server.
The Data Migration Assistant (DMA) file that is used to migrate data from 4.x to 5.1(1) releases includes the Host Name/IP Address value. When you migrate data by using DMA, the Host Name/IP Address (Servername) for the publisher server gets imported into the 5.1(1) database as follows:
â¢If the Host Name/IP Address (Servername) was a Host Name, the installation program compares this Servername to the provisioned Hostname for the 5.1(1) server (either through static provisioning or DNS/DHCP). If a mismatch exists, the installation program does the following actions:
-Uses the provisioned Hostname as the Host Name/IP address for the 5.x server, overriding the servername in the DMA file.
-Notifies you about the mismatch and its resolution.
-Prompts you to proceed or cancel the installation.
â¢If the Host Name/IP Address (Servername) was an IP address, the installation program compares this Servername to the provisioned IP Address for the 5.x server (either through static provisioning or DNS/DHCP). If a mismatch exists, the installation program does the following actions:
-Uses the provisioned IP Address as the Servername for the 5.x server, overriding the servername in the DMA file.
This feature allows you to import your 4.x data to a 5.1(1) server without having to preserve the IP Address or Host Name. The IP Address and/or Host name of the 5.1(1) server can differ from the 4.x servername.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/upgrade/5_1/upgrd511.html#wp46919
Just be very careful with this note from Gonz;
This feature will result in a bad DB records if, during the W1 upgrade, the user tries to set the new publisher's name or IP to values that ***existed in the cluster on another server during the DMA backup.
This note is now in the docs;
***Caution Do not assign a hostname or IP address to the upgraded server that is already assigned to another node in the cluster. Doing so causes the cluster upgrade to fail.
Hope this helps buddy!
Rob
02-12-2008 07:27 AM
Hi Deji,
Hope all is well :)
Rob
02-12-2008 08:04 AM
Thanks Rob,
This clearify things. Its relief to know that the this feature is available now.
02-12-2008 08:34 AM
Hi Deji,
You are always welcome here! Unless this is absolutely necessary I would try to avoid this change (just my paranioa :) There are already many variables involved with this upgrade (but it is now supported).
Just my 2 Cent$
Rob
