paolo bevilacqua Tue, 02/12/2008 - 07:40
  • Hall of Fame,
    Founding Member
No, whne necessary you apply the desire compounding type (A-law or U-law) under voice port, and the desired codec under the voip DP where the call goes out.
UCBNOCWAN Tue, 02/12/2008 - 07:45
Paolo,
So there is absolutely no way it can be assigned to pots dial peer, it works only on voip dial peers?
Das.
Correct Answer
paolo bevilacqua Tue, 02/12/2008 - 07:52
  • Hall of Fame,
    Founding Member
There is way because isn't needed, codec is associated with voip so you set it there.
paolo bevilacqua Tue, 02/12/2008 - 08:30
  • Hall of Fame,
    Founding Member
Of course I meant "there is no way". Thank you for the nice rating, I hope it's understood that my answers are always a bit short because I try to get "to the juice" all the time.
