02-12-2008 07:40 AM - edited 03-03-2019 08:40 PM
02-12-2008 07:46 AM
Check this link for chassis http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html#~chassis
Check this link for supervisor http://www.cisco.com/en/US/products/hw/switches/ps4324/prod_models_comparison.html#~supervisor
Most notable are the line card speed of 4500-E models supports 24Gbps while the 4500 models supports only 6Gbps.
Dandy
02-12-2008 07:46 AM
Dandy
02-12-2008 07:51 AM
Major difference is that the E-series chassis support the new sup6E which provides 24gbps/slot of switching capacity with the new E series line cards as against the 6 Gbps/slot supported by the 4500
SuP6E runs on centreflex technology that deliver extremely high centralized performance and configuration flexibility
More info here
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/prod_qas0900aecd806d8b06.html
Narayan
