Boot system image from TFTP
Feb 12th, 2008
I have a Windows TFTP Server on Vlan 100 which is directly connected to my router.
How can I setup my router to Boot a system image from the TFTP Server?
Is it possible?
Overall Rating: 3 (3 ratings)
Hi, I read your posting and you have the server connected to a port on vlan 100? can you ping the tftp server IP? the command copy tftp: flash: then follow the prompts, make sure your IP address of the remote server is correct, the TFTP program is started on the server and the file name is entered correct. Use the verify flash command after you download the image, and you can use the boot system flash: when you reload the device. Read through the document below it has great information on loading IOS from several sources. HTH
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml#step6
7200#copy tftp: flash:
Address or name of remote host []? 172.22.1.84
Source filename []? c7200-a3js-mz.122-15.T16.bin
Destination filename [c7200-a3js-mz.122-15.T16.bin]?
Accessing tftp://172.22.1.84/c7200-a3js-mz.122-15.T16.bin...
Erase flash: before copying? [confirm]n
Loading c7200-a3js-mz.122-15.T16.bin from 172.22.1.84 (via GigabitEthernet0/1):
[OK - 19187152 bytes]
glen.grant Tue, 02/12/2008 - 17:20
Think he was talking about booting from a tftp server instead of downloading a image . You could try this , this is not really a common practice of taking the boot image froma server you normally just boot the image out of flash.
boot system tftp filename [ip-address]
