ASA5520 IPS, not seeing any traffic
Feb 12th, 2008
I have the IPS set to promiscuous mode.
Have a policy map set don't see it doing anything I get no reports or logs I see no traffic on it.
How do you know what it's doing? or get it to do something?
I don't even know what questions to ask as the documentation for this thing is horrible.
access-list IPS extended permit ip any any
access-group Outside_access_in in interface Outside
access-group Inside_access_in in interface Inside
route Outside 0.0.0.0 0.0.0.0 xx.xx.xxx.1 1
route Inside 10.0.0.0 255.0.0.0 10.1.7.50 1
class-map IPS-CLASS
match access-list IPS
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 1024
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect icmp
class IPS-CLASS
ips promiscuous fail-open
abinjola Tue, 02/12/2008 - 13:05
sh run service-policy (will tell you if this policy is applied anywhere)
sh service-policy (will tell you if IPS is inspecting)
doering Tue, 02/12/2008 - 14:42
Have you configured the AIP-SSM yet? You currently show the ASA configuration. And it looks like your going to send traffic to the AIP. Could you session into the AIP from the ASA and make sure that you have configured it as well?
