How to access routing module on 6509 in order to enter wccp commands
Answered Question
Feb 12th, 2008
Hi folks, sorry for this basic question, but in the past I worked with the old cat 5000 and I used to access the routing module.
If I have a 6509 running IOS, imagine I need to execute commands on the routing module for such switch, is there any need/way to access the routing module in order to input commands. the commands I will enter:
Router-Switch(config)#ip wccp version 2
Router-Switch(config)#ip wccp 61 redirect-list MYWAAS61
Router-Switch(config)#int VLAN50
Router-Switch(config)#ip wccp 61 redirect in
Correct Answer by Jon Marshall about 9 years 3 months ago
If you are running in Native mode ie. IOS for both the supervisor and the MSFC then you just log into the 6500 and it is all IOS.
If you are running in Hybrid mode ie. CatOS on supervisor and IOS on MSFC then from switch in enable mode type
switch# sess 15
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Tue, 02/12/2008 - 10:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
switch# sess 15
Jon
