Loading newer IOS on 2960 Switch.
Feb 12th, 2008
I have (2) 2960 switches. One is newer then the other and I wanted to update the other switch with the latest software so that I have the same software on the 2960's.
On SWA the IOS is C2960-lanbase-mz.122-25.SEE2.bin
On SWB the IOS is C2960-lanbase-mz.122-35.SE5.bin
The dir that they are in are C2960-lanbase-mz.122-35.SE5 and C2960-lanbase-mz.122-25.SEE2. I tar the SWB IOS and have it on the tftp server and even xtracted it to flash on SWA. This way I have all the files inside the folder with it.
The problem is when I run the archive download-sw flash: or from tftp I get an error
%Error opening flash:update/info (No such file or directory)
Error: Image is not a valid IOS image archive.
Can I not replace the IOS for some reason?
glen.grant Tue, 02/12/2008 - 13:05
  • Purple, 4500 points or more
Are you using a .tar file ? You can't use the archive command on a .bin file . What syntax are you using when trying to download? Can you post the whole command?
jmaurer1205 Tue, 02/12/2008 - 14:21
Yes Im using a .tar file. I created it with archive tar /create tftp://ip/save.tar flash:bin file
I have that working. When I run the
archive download-sw /overwrite /reload tftp://192.168.1.199/c2960-lanbase-mz.122-35.SE5.tar
These errors happen with out the 2 options overwrite and reload.
HQ-xdc-swB#$/reload tftp://192.168.1.199/c2960-lanbase-mz.122-35.SE5.tar
Loading c2960-lanbase-mz.122-35.SE5.tar from 192.168.1.199 (via Vlan192): !!!!!!
[OK - 8609792 bytes]
examining image...
extracting info (476 bytes)
ERROR: Image is not a valid IOS image archive.
HQ-xdc-swB#
I did get it to load by tftping and xtracting the file to a file and changing the boot system. But dont know why it wouldnt work the way it should.
glen.grant Tue, 02/12/2008 - 15:48
Unless you need GUI function you don't really need the tar file and could just use the .bin file. I'm not sure if there is enough space in flash on the 2960's for 2 images or not , if not just delete the current .bin or directory and copy or tftp the new one in . Just check to see how much space you have left in flash, "dir flash: and see if the .bin will fit in there if not then delete the old image . Then just do a copy tftp flash: , hit enter it will ask server ip , put that in hit enter and it will ask you the filename at which point you put in the filename like c2960-lanbase-mz.122-35.SE5.bin, hit enter and it should download . Set your boot statement if you have more than 1 image in flash otherwise it will find it without a boot statement if its the only image.
