Cisco Rate Limiting Done Microsoft Style
bimckenz Tue, 02/12/2008 - 11:54
What IOS version do you have on it? Note below:
In Cisco IOS Release 12.2(25)SE or later, you can only configure individual policers on an SVI.
In software releases earlier than Cisco IOS Release 12.2(25)SE, you can configure policing only on a physical port. You can configure the trust state, set a new DSCP or IP precedence value in the packet, or define an individual or aggregate policer. For more information, see the "Policing on Physical Ports" section.
In Cisco IOS Release 12.2(25)SE or later, you can configure policing on a physical port or an SVI. For more information about configuring policing on physical ports, see the "Policing on Physical Ports" section. When configuring policy maps on an SVI, you can create a hierarchical policy map and can only define an individual policer in the secondary interface-level policy map. For more information, see the "Policing on SVIs" section.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swqos.html#wp1253412
It's really the same on both switch models if you have the same IOS version/feature set. Doing a show ver or dir at the CLI will show what you're running.
