SSL tunnel for LAN to LAN
Feb 12th, 2008
I am designing a temporary solution for VPN as a backup. This is using a ASA, and SSL VPN.
The problem I have is, I have to terminate SSL VPN on a Linux box/firewall on other end. I need LAN to LAN connection with SSL VPN from ASA to Linux systems.
So my questions are -
As I can't use any client on other side for SSL VPN, can I use clientless VPN configuration for Linux to allow entire LAN network on Linux side to pass on VPN?
Is there any other better way?
One more option I have, is to use openvpn software on Linux end this supports LAN to LAN SSL VPN.
