Problems whit CUE
Feb 12th, 2008
Hi all, I have the next problem:
In all the extensions when you dial locally or from the pstn using the Auto Attendant and even if the extension has a mailbox CUE says the following: "there is no mailbox assigned for this extension"
This was working until today.
Any suggestions is apreciated.
Juan Carlos Ari... Tue, 02/19/2008 - 10:22
Luis, check the status of the CUE with the command:
service-module service-Engine 1/0 status
where 1/0 is the interfece number, if is not in steady state, maybe is damaged, AIM-CUE has a lifetime, also check taht did not crashes, maybe you shutdown your router several times without shutting down the CUE module.
Hope this help.
