02-12-2008 03:06 PM - edited 03-14-2019 01:50 AM
Anyone using a third party vendor for call recording. If so, who are you using and better yet do you recommend them?
02-12-2008 08:54 PM
You have a sea of options but first you need to define your platform
define your requirements
define your budget that should narrow your list quite a bit.
for enterprise you may want to look at Verint, Witness, call rex, so on
express or UCX you can go with some low end vendors as well but Verint, witness can play as well.
If you need for emergency recording not for quality monitoring then consider Cisco's own solution that comes with agents software.
02-13-2008 05:34 AM
Hi ,
There is alot of variety Call Recording System
but from experience for Contact Centers,
Speechlog Call Recording from Globitel
Abdulla
02-13-2008 05:58 AM
I have worked with Witness from Verint and it is a very powerful recording soluiton for CallManager, IPCC Express or Enterpise.
It provides quality monitoring, all calls recording, record on demand, services to record a call from an IP Phone Service and some other features.
Hope this helps,
Juan Luis
02-13-2008 07:53 AM
Thank you all for the responses. My apologies, I should have elaborated more on the reason for my question. We are currently looking at bringing IPCC express in house for our call center requirements and want to be able to record calls primarily for training purposes.
Again, thanks to all.
02-13-2008 08:15 AM
If you are looking for a simple solution for full time and/or rules based recording you can check out our Aware product. Designed exclusively for CCM, so it supports IPCC and Extension Mobility well.
http://www.netelligent.com/products/aware/default.aspx
Good Luck,
Peter
