Potential T1 clocking prolems?
Feb 12th, 2008
Our customer purchased a 2851 but instead of the vwic2-mft's they bought the vwic-mft's (first generation). Will there potentially be clocking issues for below setup?
vwic-2mft - 1st port used for incoming PRI, 2nd configured as PRI and connected back to back to NM-1CE1T1-PRI (this setup is to get modem calls into NM-1CE1T1-PRI and onto PVDM2-12DM)
second vwic-2mft - port one and port two will be for frame-relay connections.
vwic-1mft (T1 connection up to MPLS network).
thanks
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 02/13/2008 - 00:39
  • Hall of Fame,
    Founding Member
Hi, you should have no issues. Each wic can be off independent clocks. Don't forget to configure network-clock-participate.
Also, you can now terminate the modem calls directly using the vwic, it's in some new IOS, I can't find the release notes now, but I will eventually.
