Fixup SMTP stops mail traffic???
Feb 12th, 2008
I have 2 ASA's they have both been running for over a year. Suddenly 1 stopped passing SMTP traffic. I couldn't telnet via port 25 either. A quick google search and I find a tip that says to take out the fixup SMTP line from the config. Suddenly the mail is flowing again. Anyone run into this before?
abinjola Tue, 02/12/2008 - 18:06
If you have fixup smtp turned on and the mail server supports ESMTP then you would have to necessarily turn off the fixup smtp
abinjola Wed, 02/13/2008 - 06:38
yes ASA all fixups are turned into Inspects..equivalent of fixup smtp is inspect esmtp.
tschimmel Wed, 02/13/2008 - 09:01
I had this issue the other day, and it was an issue with McAfee. The new patch applied to the server on our DMZ had a bug and stopped passing port 25. Nice huh? Have your ITRO guys been tinkering?
