EAdmin missing DirectoryID
Feb 12th, 2008
Unity 5 on exch2003:
The Unity_server, USbms, and EAdmin accounts failed to be created during install. I went back and ran setup.exe /sync and they now exist, everything is functional with no app errors.
When I run dbwalker it says the DirectoryID field for EAdmin is "null". I checked SQL and it is not there unlike the other accounts.
Any way to manually insert this in the table? Should I try sync again?
Scott
ranpierce Wed, 02/13/2008 - 05:32
  • Silver, 250 points or more
The /sync is a sync between ad and sql. If the accounts were not in ad before and you ran sync and now they are it is because it synced with sql and found them.
Which tables in sql are you looking at? Are the accounts in AD?
What version of dbwalker are you running? Might be a dbwalker issue.
I have Unity 4.2.1 Installing a higher version today so I can help better.
rlp
