7921G Firmware update
Feb 12th, 2008
I just purchased a 7971G phone and I tried updating the firmware to 1.1.1 using a USB connection since I cannot connect to my wireless network since it is using PEAP.
I was unable to determine the current firmware so I logged into the device's website and tried to upload the 1.1.1 tar file...the secondary progress bar hung near completion but never completed. Even after 45 mins.
I then read that 1.1.1 required 1.04 minimum...so I successfully updated the device to 1.0.5 with no issues.
I then tried the 1.1.1 update and it hung for 30 mins, never completing the secondary progress box. If I click in that box, it goes away and the main Upload page just sits there.
I appreciate any ideas. I cannot connect to my wireless network and then to CM until I get this firmware loaded.
migilles Tue, 02/12/2008 - 20:38
  • Cisco Employee,
There are no issues there.
Not sure if you have an active network profile, but can try to disable all profiles and retry.
maloyal Tue, 02/12/2008 - 21:09
The only active profile is the default Cisco profile that comes on the phone.
I will see about disabling or removing that completely and trying again.
maloyal Wed, 02/13/2008 - 06:55
I unchecked the default cisco network profile and the phone says "No Network Profile" and the update is still not completing. I've tried 2 different firmware downloads just to make sure it wasn't corrupt.
I've reset the phone numerous times.
maloyal Wed, 02/13/2008 - 10:03
Success!
I had to do a reset holding down the "..." key and the speakerphone key. When it asked to be USB docked, I docked it and it started flashing "http://192.168.1.100"
I opened my browser to that webpage without the https and it immediately loaded a firmware update page. I uploaded the 1.1.1 firmware and it finally worked.
I don't recall reading this procedure in any of the docs I downloaded.
