02-12-2008 09:16 PM - edited 03-05-2019 09:07 PM
When power up switch it directly goes in the mode that shows ROM>.
ROM> ?
Commands:
r Read memory
w Write memory
d Dump memory
t Test memory
c Call address
0 Dump CP0 regs
q Quit (return)
ESC Reset system
ROM>
So i am requesting to know how will i come back my switch in normal operation.
Imran
02-12-2008 09:35 PM
Enter ">reset" or "boot" to boot into normal mode.
Usually the switch goes into ROMMON mode due to various reasons like config reg setting changed,ios image corrupted/deleted. Please check n reply.
Rate if it helps..
*aijaz*
02-12-2008 11:18 PM
Thanks for reply. But "reset" command is not available. Only option is there " Press ESC for reset. When I press ESC it resets but comes again in ROM mode.
02-12-2008 11:44 PM
Can you post the complete booting process information....it might help us..
Thanks...
02-13-2008 01:08 AM
Post the boot process.
Goutam
