Hardware upgrade from 3620 router !!!
Feb 12th, 2008
  • Gold, 750 points or more
Hi netpros,
I need to upgrade a Cisco 3620 to a supported Cisco equivalent device. The customer uses this device for dedicated dial up remote access solution (ONRAMP10). Appart from access server, this device does nothing else. I am thinking a Cisco 2800 series or even a 1800 series ( I am not sure about this one). Your expert advice is much appreciated. Please see the relevant shows of the current device.
SydRas#sh ver
IOS (tm) 3600 Software (C3620-I-M), Version 12.1(5)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 26-Feb-01 21:15 by ccai
Image text-base: 0x60008950, data-base: 0x60A26000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-I-M), Version 12.1(5)T5, RELEASE SOFTWARE (fc1)
SydRas uptime is 1 day, 1 hour, 6 minutes
System returned to ROM by reload at 12:34:24 Sydney Mon Feb 11 2008
System restarted at 12:35:09 Sydney Mon Feb 11 2008
System image file is "flash:c3620-i-mz.121-5.T5"
cisco 3620 (R4700) processor (revision 0x81) with 26624K/6144K bytes of memory.
Processor board ID 25121822
R4700 CPU at 80Mhz, Implementation 33, Rev 1.0
MICA-6DM Firmware: CP ver 2720 - 5/30/2000, SP ver 2720 - 5/30/2000.
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
11 Serial network interface(s)
30 terminal line(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
SydRas#sh controllers e1
E1 1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (414 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
E1 1/1 is down.
Transmitter is sending remote alarm.
Receiver has loss of signal.
Data in current interval (416 seconds elapsed):
0 Slip Secs, 416 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 416 Unavail Secs
0 Slip Secs, 86400 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
controller E1 1/0
pri-group timeslots 1-10,16
interface Serial1/0:15
no ip address
encapsulation ppp
isdn switch-type primary-net5
isdn incoming-voice voice
interface Group-Async0
ip unnumbered Loopback1
encapsulation ppp
async mode dedicated
peer default ip address pool dialin_pool
ppp authentication ms-chap
group-range 1 30
Overall Rating: 4 (1 ratings)
paolo bevilacqua Wed, 02/13/2008 - 01:20
  • Hall of Fame,
    Founding Member
Hi, yes a 1841 would do, there is now out a new 8 port async card in for of wic, would that work for you ?
Fernando_Meza Wed, 02/13/2008 - 03:17
Thanks Paolo,
Do you know the part number for that card .. so that I can do more research. Also would I be able to configure the ISDN part (ONRAMP10) similar to the current configuration as well ..?
appreciate your feedback !!!
paolo bevilacqua Wed, 02/13/2008 - 03:44
  • Hall of Fame,
    Founding Member
Fernando_Meza Wed, 02/13/2008 - 05:23
Thanks Paolo,
that was very helpful .. so would you agree that I should be OK with a 2811 plus a Channelized T1/E1 and ISDN PRI Module and a 12 ports integrated digital modem.
your response is much appreciated !!!
