ISDN PRI Voice E1
Feb 12th, 2008
the SP provided a ISDN PRI voice E1 (q931)and told me they have enabled 4 channels for testing. when i plug the link to router, there is an alarm in the router and SP's rack alarms get cleared. attached herewith router config and error when trying to make a call.
when loop E1 port, it's perfeclty working.
*Feb 13 05:38:38.243: ISDN Se1/0:15 **ERROR**: CC_CHAN_GetIdleChanpri: Interface
de-Activated
*Feb 13 05:38:38.243: ISDN Se1/0:15 **ERROR**: CCPMSG_OutCall: fails with cause
0x22
Paolo Bevilacqua Wed, 02/13/2008 - 01:16
Hi, something seems wrong with the circuits, please send output of "show controllers e1" and "show isdn status".
rasankalakmal Wed, 02/13/2008 - 09:40
but SP's rack alarms got cleared and the E1 port indicators as follows.
CD-green
LP-nothing
AL-amber
Paolo Bevilacqua Wed, 02/13/2008 - 11:50
Hi, you said you got four channels for test, but your pri-group is configured with 31. The connected switch is telling you that exactly.
Shutdown voice-port, remove pri-group, reconfigure it with timeslots 1-4 and you should be going.
Paolo Bevilacqua Wed, 02/13/2008 - 12:16
Now you have to ask your telco why the call is not accepted on channel 4. Sometime they say they have done everything, just to find isn't quite the case.
