Variance command in Eigrp/IGRP
Feb 12th, 2008
Hi ,
Can any one tell me what is the use of Variance command and where all we can use this..
Thanks in Advance,
Overall Rating: 4 (2 ratings)
Goutam Sanyal Wed, 02/13/2008 - 01:35
The variance command is a multiplier when the value supplied with the variance command is multiplied by the lowest-cost metric, it must exceed the higher-cost metric in order for the higher-cost route to be added.
In a simple its use in the case og IGRP & EIGRP to load-share between links of un= metrics.
Pls rate if it helps u!!!
