channel-group is not working Tengigabitethernet interface
Feb 13th, 2008
Team,
I have configured port-channel88 on catalyst 6509-E switch but when i tried to configure the this channel on tengigabit interface getting the following error message.
***************************************ERROR MESSAGE*******************************
(config-if)#Channel-group 88 mode on
Command rejected (Port-channel88, Te1/1): Either port is L2 and port-channel is
L3, or vice-versa
*************************Ten gigabit interface 1/1*************************
interface tengigabitethernet1/1
no ip address
channel-group 88 mode on
*****************************port channel************************
interface port-channel88
no ip address
switchport
switchport mode trunk
switchport nonegotiate
storm-control broadcast level 20.00
Any help will be highly appreciated.
Khan
aijaz802 Wed, 02/13/2008 - 00:18
Hi Khan,
On Te1/1 interface make it switchport and trunk with encapsulation. W/o switchport command the interface is a L-3 interface.
no ip address
switchport
Pls. rate if it helps..
*aijaz*
azmath.hk Wed, 02/13/2008 - 01:09
Aijaz,
Thanks for your reply. Is there any documentation for this on cisco site for more details because i need to see cisco documentation before i modify the configuration.
Sure i will rate your comment.
aijaz802 Tue, 02/19/2008 - 02:46
Pls. let me know whether my solution worked or not...
If worked..pls rate it..
Thanks..
