Direct Lines over h323
Fady Hwalla
How to configure Direct Lines over h323?
Thanks.
paolo bevilacqua
That is done with the commands "plar" or "trunk" under voice-port. There is much documentation on CCO about that.
do you know a link for an example about this?
Thanks.
Type "configuring plar" in the search box and you will get many results.
