Blocking network
Feb 13th, 2008
I've got my VPN working.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbf7b12
I would like to, that all client's traffic is tranfered over the tunnel.
How can I get this working?
I unchecked "Allow local LAN access"
massimiliano.se... Wed, 02/13/2008 - 04:27
  • Silver, 250 points or more
You don't have to define and then apply split tunnel.
If you select in Cisco VPN CLient status->statistics->Route details you must have "Secured Routes 0.0.0.0 0.0.0.0", that is all traffic is secured (transferred over the VPN tunnel).
I hope this helps,
Best regards.
Massimiliano.
tbrinkma Wed, 02/13/2008 - 04:31
Havent got that one.
Only the client VPN and our internal LAN..
tbrinkma Fri, 02/15/2008 - 00:18
Can sombody tell me how do I get the Secured Routes 0.0.0.0 0.0.0.0 on my client side of the VPN?
