unity express backup
Feb 13th, 2008
Can anyone tell me what returnvalue:6 is on a failed attempt to backup unity express. I can access the ftp server from a pc but not from unity express. ftp server is pingable from unity express subnet. thx
Overall Rating: 2 (1 ratings)
Brandon Buffin Wed, 02/13/2008 - 06:05
If you do "show backup history" from the CUE module, you should see a description of the reason for failure.
Try indicating the source interface for FTP traffic with the following command:
ip ftp source-interface
whanson Wed, 02/13/2008 - 07:30
Thanks Brandon,
The error seems to indicate that cue can't get to the server. There has to be something else going on as I ftped the config of the cme
using the voice vlan as the source with no problem. I don't see anywhere that you can set ftp source in the cue module and in any event it really only has one interface.
whanson Wed, 02/20/2008 - 09:50
In cue 2.3 if the password used to access the ftp server has any special characters in it, the backup will fail.
Mohit Grover Sun, 04/08/2012 - 22:10
I'm facing the same issue, but slightly differ. while backing up my unity express information....
Reports---> Backup History:
HistoricalData: Failure Connection to backup server failed: ftp://X.X.X.X/mrv-unity: returnvalue:7
Unable to connect to backup server
FTP Server is pinging successfully:: no problem in connectivity, from FTP Server to Unity Express & from Unity Express to FTP Server, all routing is well & going on reachable....
Reply from X.X.X.X: bytes=32 time<1ms TTL=63
why i'm getting this error:
In Unity Express ---> Reports ---> Backup History.
what should i do for this issue....
honestly i've done lots of R&D regarding this, but still problem is there....
Num_of_Revs             = 2
Category_0      =     Data
Data_lastbackup_index      =     0
#Details of last 2 backups
#Details of the last successful restore
Data_restore_backupid     =
Data_restore_date     =
Data_restore_backupdate     =
Data_restore_description     =
ronpatel Sun, 04/08/2012 - 22:15
Do you have special charctors in FTp password. If yes do not use them and try to do backup again.
Ronak Patel
Please rate helpful posts.
Mohit Grover Sun, 04/08/2012 - 22:26
Hey Ronak, thanks for your reply, But the password is simply:    abcd
I have tried all possible things,
Do you have any idea related to Return Value:7, then that shall be good try...
Mohit Grover Mon, 04/09/2012 - 01:30
Hey man, that's is simple backup configuration guide with MS-FTP server, But as you know i'm facing some problems while backing up my CUE infor.
check out 1:
why this error is showing in Log, (Routing & Switching section is all reachable, Perfectly)....
check out 2:
(this ERROR is still there & i think the resolution is behind that)
So Lets See.......
Mohit Grover Fri, 08/17/2012 - 11:49
Hey Guys, I've done backup/restore of almost all Unifed Component with freeSSHd, this application is working properly, & I've done backup  & restore of CUCM, unity connection, Unity Express, UCCX, etc....
Just google it with the keyword (freeSSHd download link), this application is open source, & you can download it for free.
this is download link as of now:     http://www.freesshd.com/?ctt=download
So enjoy :: for any further help, continue to mail me @ [email protected]
Mohit Grover
CCIE Voice # 35961
BCA (Network Communications)
MBA (Business Strategies)
