Monitor logging on PIX515(E)
Feb 13th, 2008
We have a PIX515(E) and we want to monitor the traffic. So that we have the posibility to see which user is visiting which websites and how often. I believe there is a certain logging command, isn't there?
Could anyone tell me which logging that would be and how to turn in on?
Thanks in advance.
abinjola Wed, 02/13/2008 - 06:36
Logs at debug level would not tell you which website you visits but would definitely tell you the ip address..along with the ports information...
First you would need to install a syslog server software on one of the computers. You may
download one of the popular kiwisyslog server from .
It is listed as Kiwi Syslog Daemon and latest version is 7.1.0. You may download standard
edition that runs as a program.
Once the syslog server is installed you will then need to login into the PIX in
configuration terminal mode and enter the following commands.
logging host [in_if_name] ip_address
(example: logging host inside
We are assuming syslog server is installed on computer with IP address in the
inside network.)
logging timestamp
logging trap 7
logging on
"Logging on level 7 is only for debugging purposes and do not leave pix on level 7 "
see if this helps !
cisco24x7 Wed, 02/13/2008 - 07:52
logging on
logging host
logging timestamp
logging trap 6
you do NOT need "logging trap 7" to tell you which website users visit. "logging trap 6"
will generate less syslog messages and it also
can tell you which website user(s) visit.
They both can tell you the same thing but
"logging trap 6" generates much less message.
I am not a windows person. If you use
Linux/Unix syslog-ng, you can have granular
syslog than windows. Just make sure you
have the "-r" option in your syslog config
so that it can accept syslog from other
CCIE Security
dannypostma Thu, 02/14/2008 - 03:26
Alright, thanks everybody for the answers. I will read the documenation and I'll let you know if it resolved my problem.
With Kind Regards,
