Format Compact Flash memory into Csico File System
Feb 13th, 2008
Is it possible to format (into Cisco file system) a compact flash memory (no name) from windows to be ready for receiving an IOS into a CCME ?
regards
Olivier
davetucker Wed, 02/13/2008 - 06:59
  • Bronze, 100 points or more
Olivier,
In my experience it is better to TFTP the files to the Flash using a 3Com Daemon.
You can add an IOS and CCME files to a CF Card from a PC. However, when you insert it into the PC DO NOT FORMAT IT! I think i am right in saying that you can only format the flash cards from the router itself...
A guide to working with CompactFlash guides can be found here. http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_cflash.html
Hope this helps, if so please rate!
Dave
mciarfello Wed, 02/13/2008 - 19:15
  • Silver, 250 points or more
I have also had more success with formatting it on the router first. But the referenced document mentions you can do it either way.
Another thing to look out for is CCME uses case-sensitive file names. If you use windows or DOS to copy the CCME files to the flash, it may mess up upper / lower case letters in the filename. Better do TFTP with the ARCHIVE /tar command.
NOW. I don't know (guessing NO) if Cisco would support a no name brand compact flash card.
