desciphering 'sho policy-map'
Feb 13th, 2008
Hello, can anyone help me decipher the output of the show policy-map command?
For example:
#sho policy-map interface gigabitEthernet 3/2
class-map: abc-in (match-all)
Match: access-group name permit-any
set dscp 38:
Earl in slot 3 :
65458224006738 bytes
30 second offered rate 145067856 bps
aggregate-forwarded 65458224006738 bytes
My question is what each output is; Earl, offered rate, and aggregate-forwarded.
- TM
Edison Ortiz Wed, 02/13/2008 - 16:21
Earl stands for Encoded Address Recognition Logic.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008014f8a8.shtml#topic3
It says you have an EARL in Slot3, so it must be a line card with a DFC in it.
The other 2 lines means, it has processed 145Mbps in the last 30 seconds with a total of 65458224006738 bytes since that class-map was applied.
HTH,
__
Edison.
e.maloney Thu, 02/14/2008 - 13:12
great! Thanks so much. After making some policy-map changes I can see it's working.
Thanks again,
- TM
