configuring pix 501 to access the internet
Feb 13th, 2008
I need your help.. I have configured my pix501 outside and inside ip address... I think everything is in place but I still cannot access the internet. I am attaching my present configuration.. Thanks
hareskhan Wed, 02/13/2008 - 10:59
I find the statement "nat (inside) 1 192.168.43.0 255.255.255.0 0 0" when you already have "nat (inside) 1 0.0.0.0 0.0.0.0 0 0". Though this should not be a problem, you don't need it. Have you tried to ping 203.131.103.177? Source your ping from the outside interface. Configuration looks correct and it looks like a connectivity problem between your PIX and ISP router.
felcaruana Wed, 02/13/2008 - 11:35
Yes I have ping 203.131.103.177 and its not replying. I dont think its the connectivity because I can connect to the internet without the pix in the network.
Jon Marshall Wed, 02/13/2008 - 11:46
Why do you have this statement
static (inside,outside) 192.168.43.0 192.168.43.0 netmask 255.255.255.0 0 0
This says not to NAT any of the 192.168.43.0 address as they go from inside to outside and takes precedence over your nat/global statements.
Remove that statement, do a "clear xlate" and try again.
Jon
felcaruana Wed, 02/13/2008 - 11:55
Thanks Jon.. How can I delete this entry? what is the exact command?
Jon Marshall Wed, 02/13/2008 - 11:57
pix(config)# no static (inside,outside) 192.168.43.0 192.168.43.0 netmask 255.255.255.0
Don't forget you then need to clear the xlate translations
pix# clear xlate
Be aware that the "clear xlate" will remove all existing connections through your firewall but it sounds like this is not a problem at the moment.
Jon
felcaruana Wed, 02/13/2008 - 13:23
Hi Jon, I did everything you said but I still can't connect to the internet... I cannot ping the outside ip but I can ping the inside ip...
JORGE RODRIGUEZ Wed, 02/13/2008 - 13:45
can you post the interface status of your outside interface, to where is the outside onnected to , a switch ? if a switch make sure outside interface is in same vlan as ISP router, if you have outside interface directly connected to a router that is not magageable by you I would recommend your interface outside be autodetect for speed transmission.
e.g
show interface ethernet0
felcaruana Wed, 02/13/2008 - 14:01
Here it is.. but as of now it is disconnected from the network ..
AOSMANPIX(config)# show interface 0
interface ethernet0 "outside" is up, line protocol is down
Hardware is i82559 ethernet, address is 000b.5f37.bc48
IP address 203.131.103.176, subnet mask 255.255.255.0
MTU 1500 bytes, BW 10000 Kbit half duplex
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/0)
output queue (curr/max blocks): hardware (0/0) software (0/0)
felcaruana Wed, 02/13/2008 - 14:06
here is it buddy. Thanks..
Jon Marshall Wed, 02/13/2008 - 14:14
Okay, after typing that rather long post :) Jorge has hit the nail on the head. Your outside interface is showing down. You need to check the physical connectivity as suggested by Jorge.
Jon
felcaruana Wed, 02/13/2008 - 13:57
Jon Marshall Wed, 02/13/2008 - 14:12
In addition to Jorge's suggestions which you need to check can you ping the ISP router IP address 203.131.103.177 from the firewall.
To test this you may need to temporarily add an extra line to the config
pix(config)# icmp permit 203.131.103.177 255.255.255.255 outside
You will not be able to ping the pix outside interface IP address from a machine on the inside network - 192.168.43.x. So you need to check connectivity in other ways.
If you can ping the ISP router then
1) try pinging a host on the Internet by IP address from the firewall
2) If 1) works try pinging from an inside host - 192.168.43.x. Again you need to ping the IP address at first.
If you can't ping your ISP router then you need to start checking physical connectivity and any switch config as suggested by Jorge.
The other thing you can do with pix v6.x is debugging the packets.
So
If you can ping the ISP router address from the firewall but you cannot from an inside address try on the firewall
pix# debug packet inside dst 203.131.103.177
pix# debug packet inside src 203.131.103.177
This will show you the packets arriving and leaving on the inside interface destined or coming from the ISP address.
You can also run these on the outside interface ie.
pix# debug packet outside dst 203.131.103.177
pix# debug packet outside src 203.131.103.177
Be careful with debugging on a live system - you should be okay if you specify the source or destination as above.
To turn off debugging
pix# no debug all
Jon
