PRI Provisioning
Feb 13th, 2008
I have a Cisco 2811 with a NM-2CE1T1-PRI network module. We plan to use this for backups via demand dial routing to remote Cisco routers with BRI cards.
I am placing my PRI order and was sent this provisioning form to fill out. It seems very PBX specific so I need a little help.
General Provisioning Information
Framing: I put B8ZS/ESF
Digits to complete call (3/4/10): I put 10
DS1 Specific Provisioning Information
Out pulse type (DTMF or Dial Pulse): ??
Supervision Signaling: (E&M or Other): ??
In & Out Start Signaling (Immediate or Wink): ??
Outgoing Trunk Selection: ???
Dial Tone (PBX Provided or Carrier Provided): ??
Thank you in advance,
Overall Rating: 5 (1 ratings)
jim_berlow Wed, 02/13/2008 - 09:21
The framing and digits sound fine. I would ask your provider about the other parameters - I don't think they really pertain to what your doing. This is probably a generic form that is provided for all PRI's and this info would be needed if you were connecting it to your PBX.
dennylester Wed, 02/13/2008 - 20:32
Thank you for clarifying this. Hopefully they will know how to configure it on their end.
Now I need to find some articles on how to configure it on my end. :-)
Paolo Bevilacqua Wed, 02/13/2008 - 10:04
Jim is correct, the "DS1 specific parameters" would only apply for a CAS circuit, but wisely you're requesting PRI.
