PRI Caller ID Name
Feb 13th, 2008
I have a 2811 router with a PRI coming in and Unified Communications Manager Business Edition 6.0. We are receiving the caller id number and not the name on the phones. Any advice on what to look for?
Rajesh Revuru Wed, 02/13/2008 - 10:49
  • Silver, 250 points or more
First things first, is your Service provider sending calling Name? If yes
If you are using MGCP, Under your T1/PRI settings, try checking "Send Calling Name In Facility IE"
bschear Wed, 02/13/2008 - 12:13
The service provider indicates they are sending name and we are using H.323.
paolo bevilacqua Wed, 02/13/2008 - 12:19
  • Hall of Fame,
    Founding Member
Which switch type is that? If the name is sent asn.1 encoded (easy to see with debug isdn q931), you need
voice service voip
qsig decode
paolo bevilacqua Thu, 02/14/2008 - 12:38
  • Hall of Fame,
    Founding Member
Yes it does, check previous threads for the very same issue.
