CME/ Internet Access Question
Feb 13th, 2008
I am in the process of setting up a hypothetical CME system and I have most things out but I need some help with regard to getting internet access. Here is the equipment that I want to use and how I want to use it
Cisco 2811 router with ES module
Linksys WRT54G router (that will handle NAT)
Linksys Cable Modem to Comcast Cable Internet (DHCP)
Here is the scenario I have so far:
On the 2811 there are two DHCP pools created (that correspond to the two VLANS used in the network):
with addresses 10.1.10.x
where default router is
with addresses 10.1.20.x
and option 150 is (cisco CME tftp)
Likewise, the telephony-service source ip is configured as
The virtual gigabit ethernet interface on the router that connects to the ES module is configured with two subinterfaces that correspond to the two VLANs used:
So Gi1/0 (or whatever its number is)
has two subinterfaces:
Gi1/0.10 for DATA
where the dot1q is for VLAN 10
the interface ip is
Gi1/0.20 for VOICE
where the dot1q is for VLAN 20
the interface ip is
On the ES switch, the virtual gigabit port (Gi1/0/2 lets call it) is set up for trunking with dot1q and is setup to allow all VLANs across the trunk.
the individual switchports on the ES module are configured as follows:
Interface FastEthernet0/x
switchport access vlan 10
switchport mode access
switchport voice vlan 20
spanning-tree portfast
First off, I would like to use the Linksys router for web access and have it connected to one of my switchports on the ES module. The DHCP server on the Linksys would of course be off and lets say the linksys will have a static ip of and would thus reside in the DATA vlan (the linksys would of course still get the comcast internet outside IP via DHCP from the connected cable modem).
So far, if I look at this setup as it would operate it seems to me that most everything would work fine. Inter-vlan routing should be ok thanks to the subinterfaces on the router and trunk on the switch, so computers connected to the switch that are placed in vlan 10 DATA will be able to ping phones that are in the VOICE vlan. Likewise, computers will be able to access to CME as well at its address
Likewise, thanks to the DHCP computers connected to the switch will have a default router address of (the 2811).
So, as far as I understand it, all of the above inter-vlan routing from the DATA to the VOICE vlan will work because of the fact that the computers know to "ask" the router where to route packets that are not in their subnet.
Here's where the problem comes in, supposing I want internet access through the linksys router (on the DATA vlan, but that doesn't really matter, does it?) how do I let a computer know how to route internet traffic to that router without changing the default router command in the DHCP pool for the DATA Vlan?
the reason I ask this is because I thought about this for a while and at one point I figured I could just set the default router for the DATA DHCP pool to point directly to the static ip of the Linksys, however while this should give the computers internet access wouldn't it isolate the DATA vlan from the VOICE vlan altogether? After all, in this scenario supposing a computer tries to ping (the CME) and since its in a different subnet it would query the default router which is the Linksys and the ping would fail since the linksys has no way of routing the traffic between subnets?
Is one possible solution to have the following line in my 2811 config
ip classless
ip route
I unfortunately do not have the equipment on hand to test this but would such a setup work?
Any and all help is of course appreciated!!
Brandon Buffin Wed, 02/13/2008 - 11:33
My recommendation would be to take the Linksys out of the equation and allow the 2811 to route traffic to the internet.
Paolo Bevilacqua Wed, 02/13/2008 - 11:39
I agree with Michael. If you're allowed to use cable modem of your own, you can use a cable Network Module in the 2811.
Similarly for HWIC-1ADSL that is router's card for ADSL. Note, the ES module is expensive and unless you get PoE with it, doesn;t do much advantae. It can be better to get an external switch with Poe instead.
dmitrybarsky Wed, 02/13/2008 - 11:46
thank you for the quick replied. I agree that the 2811 would certainly be better for routing than the linksys. I was just wondering whether a setup such as the one I described would work? With regard to the es module I just used that as an example I have no particular attachment to it.
Thanks again I love this forum!
dmitrybarsky Wed, 02/13/2008 - 11:53
Paolo Bevilacqua Wed, 02/13/2008 - 11:57
Sure. About all the routing stuff, you should not need worry to much about. Once the router gets a packet for a destination it knows, it will route it.
All what the phones and PCs need, no matter the VLAN they're using, is a default gateway. That is the router precisely.
dmitrybarsky Wed, 02/13/2008 - 17:44
so essentially what you are saying is that I could use the config described in my initial post and I wouldn't have to even use the ip route command at all? If this is the case then how does the router know to forward packets that are meant to go to the Internet through the linksys router connected to an arbitrary port on one of my switches? I was just wondering how this works from a technical standpoint. I understand how the inter-vlan routing works on the internal network its just the connection to the Internet through a secondary router (linksys) that gets me confused. One of the reasons is because it isn't defined as a router anywhere in my config. Does the 2811 just send some sort of broadcast message when it receives packets going to tge Internet? Is that how it routes them to the outside? I was just wondering because I want to understand how this type of scenario would work.
Thanks again!!!
no the 2811 doesn't broadcast, it just routes to networks it knows about. so you have the default route of to - so the PC asks it's default gateway (2811) for a route to an internet address and the 2811 doesn't have that subnet directly connected so it forwards the packet based on it's routing table to the default route, which will take you to the Linksys and so on.
another option you have is to let the 2811 do the NAT, vlan your internal stuff and trunk it to one fastE interface and then connect the other fastE to your DSL modem. This way you can avoid another NM or WIC.
