Using Monitor interface not the transparent mode with overlappping subnets
Feb 13th, 2008
I'm trying to do the following.
Monitoring
____|___
----inside | asa | outside ------
inside is 10.0.0.0/8
outside is 87.1.1.1/30
Monitoring is 10.88.1.2/24
The problem I have is that traffic coming back to monitoring workstations that is 10.22.1.1/24 wants to return using the inside interface (using the route 10.0.0.0/8).
What I would like to do is to set it up that all traffic to the monitoring port will leave the same port instead of the inside port.
Not sure if this is possible but if you have any ideas please let me know.
abinjola Wed, 02/13/2008 - 11:10
I guess change the management port to a different VLAN and add route for that VLAN via man port
