NAC and SSL - fails to import password protected private key
Feb 13th, 2008
I am attempting to import an SSL certificate on my CCA Manager and Server. I purchased a wild card SSL cert *.domain.com. The private key used to generate the certificate was created on an Cisco ACS 3.2 server and has a password. When attempting to import the private key into the CCA Manager the browser times out and no error is reported.
My guess is that it is waiting for the password to allow access to the private key. Unfortunately there is no place on the form and no pop-up to enter the password.
Is there a command line option for importing a private key that may work for me?
Sherm
sathappan Sun, 02/17/2008 - 13:26
The best Possible way is to generate a CSR from the CCA server and then purchase a certificate using that CSR. Then you dont have problems with private keys.
sathappan
