How can i send packet across Network?
Feb 13th, 2008
Hello Guys,
How can i send data (notepad/word documents) across a network segment and not just pinging?.
I just want to have a real fell of READ data transmission and not pinging going through or not.
Thank you
Istvan_Rabai Wed, 02/13/2008 - 20:40
  • Gold, 750 points or more
Hi Netman,
You need to set up hosts on the network and establish communication between them through the configured network.
Another method to test you network is to TELNET into other routers through the network.
Also, a good test is to set up a new subnet on a router and advertise it through a routing protocol.
In a working network, the new subnet will appear in the appropriate remote router routing tables.
Cheers:
Istvan
