dmcloon Wed, 02/13/2008 - 22:46
  • Bronze, 100 points or more
you can suspend the vsan(s). The interfaces will then go 'inactive' and not forward traffic.
aleksandar.milanov Thu, 02/14/2008 - 06:00
Thank you for the answer, but I need to shutdown the MDS completely (there will be a total power outage/maintenance in this room).
mcintyre.k Thu, 02/14/2008 - 07:17
I would assume that once the VSANs were suspended and traffic flow stopped you would simply unplug the switch. I am not sure there is a command that will shutdown the MDS and power it off. I would make sure you did a copy run start command prior to shutting down so that any recent changes to the config are saved.
Trending Topics: Storage Networking
