What is the difference between SFP-GE-T and GLC-T?
Feb 13th, 2008
I have some information from this link, but I need to know if I could one for the other.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Overall Rating: 4.9 (9 ratings)
andrew.burns Thu, 02/14/2008 - 01:13
  • Gold, 750 points or more
They are operationally identical and can be interchanged with no problems - the only difference is that the SFP-GE-T conforms to NEBS Level 3 and the GLC-T doesn't. (Well, I think the SFP-GE-T costs a bit more too..)
HTH - plz rate useful posts (not just mine!)
Andrew.
astanislaus Thu, 02/14/2008 - 14:29
Thanks for the immediate reply. What is NEBS Level 3 and DOM. Anyway don't worry I will GOOGLE it.
chewington Tue, 05/20/2014 - 12:52
I'll also add that the SFP-GE-T is a little bit more expensive...maybe $40 more (retail) but it works in switches or routers like the ASR while the GLC-T is for switches only. I learned the hard way.
CSCO10662744_2 Wed, 09/02/2015 - 13:43
What happens when you put a GLC-T into a router?
Does it give you some sort of error message?
ahmad82pkn Fri, 06/24/2016 - 07:46
for me , GLC_T didnt work in ASR 1002x, but did work on ASR1001x.
dont know why, so i buy SFP_GE_T for Routers.
zinamadmin Wed, 01/18/2017 - 11:33
Ahmed, I have asro1002-x but SFP_GE_T is not wokring... can you give mt the exact nmodel numbers?
