intervaln routing
Feb 13th, 2008
How to configure intervaln routing on 4507 switch.suppose in the network 2,3,4,5 vlans are exist.
Overall Rating: 4 (1 ratings)
s.arunkumar Thu, 02/14/2008 - 00:32
Since the switch is a layer 3,just create an svi for each vlan,and give one ip corresponding to each vlans subnet.
Eg:vlan 10 -
vlan 20 -
interface vlan 10
ip address
interface vlan 20
ip address
Rick Morris Thu, 02/14/2008 - 13:46
to go along with this each port on the switch when you assign the VLAN make sure you use the correct IP as the default gateway for the host/server connected. The DG is the IP assigned to the VLAN.
Rick Morris Thu, 02/14/2008 - 13:47
you will also need to make sure IP Routing is enabled.
from CLI
in conf t mode
ip routing
This places the switch into layer 3 mode.
