02-13-2008 10:57 PM - edited 03-11-2019 05:02 AM
My pix 501 sh ver
Cisco PIX Firewall Version 6.2(2)
Cisco PIX Device Manager Version 2.0(2)
Compiled on Fri 07-Jun-02 17:49 by morlee
DR-PIX up 12 days 19 hours
Hardware: PIX-501, 16 MB RAM, CPU Am5x86 133 MHz
Flash E28F640J3 @ 0x3000000, 8MB
BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 000b.bed3.80b3, irq 9
1: ethernet1: address is 000b.bed3.80b4, irq 10
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 2
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: 50
Throughput: Limited
IKE peers: 5
If we look the doc..it says Maximum concurrent connections-7500 and
10 User License Support for up to ten concurrent connections from different
source IP addresses on the internal network to traverse the
firewall. Also provides DHCP server support for up to 32 leases.
50 User License Support for up to 50 concurrent connections from different
firewall. Also provides DHCP server support for up to 128 leases.
Unlimited User License Support for an
unlimited number of concurrent connections from
different source IP addresses on the internal network to traverse
the firewall. Also provides DHCP server support for up to 256
leases.
All the doc are saying about from inside number of host to outside conn..My concern is i m having one server in inside interface.I wanted to access this from some 300 hosts from outside..Is it my pix 501 will support the conn? r how many conn form outside to inside it would support.I think 50 hosts..Kindly provide me info...
02-14-2008 02:10 AM
Pls provide information as soon.
02-14-2008 05:44 AM
from outside to inside Pix does not consider/count the source from where you would be coming as a host defined in license feature, therefore you can have your internal server access from 200 outside machines..you are safe don't worry about the limit
example :-
static (inside,outside)
this one public ip accounts for one entry in local host table, doesn't matter how many hosts access this pubic ip
02-14-2008 06:16 AM
Thank you very much...
so Limits all about the how many inside systems we are having..
02-14-2008 06:25 AM
yes
