Etherchannel for Qos in differernt queue and threshold LAN ports
Feb 13th, 2008
Is it ok to form an etherchannel on 6500 with qos enabled and in differnent queue and threshold on LAN ports?
andrew.burns Thu, 02/14/2008 - 00:55
  • Gold, 750 points or more
Normally, etherchannels need all ports to have the same QoS structure and the etherchannel will not form if there is a difference, but you can disable this checking with the command:
no mls qos channel-consistency
HTH - plz rate useful posts (not just mine!)
Andrew.
