Routing via AUX port
Answered Question
Feb 14th, 2008
I have a dial-up modem connected to my router's AUX port.
Using this setup, I need to get remote users to access our internal servers via dial-up.
The users aren't network admins, so they should not have exec access to the routers. They only need to be able to access the servers on our system, i.e. I need to route their Laptops's traffic via the aux port to the intended server.
Is there a way of configuring the router and modem to do this? Or do I need more equipment in order for this to work?
The router is a 2960 series and the modem is a US Robotics dial up modem.
Any help is greatly appreciated. Thanks!
Correct Answer by pcameron about 8 years 9 months ago
For diarect dial connection, there should not be a lot of difference - the AUX port should run PPP automatically and as long as the PC recognises this it should negotiate and connect.
Overall Rating: 4.3 (3 ratings)
Paolo Bevilacqua Thu, 02/14/2008 - 02:27
Yes, configure ppp for the aux and dial-in. Performances won;t be stellar, but it works.
WabukiSensei Thu, 02/14/2008 - 23:11
Hi, thanks for the tip, but I thought you can't configure ppp on AUX ports?
pcameron Mon, 02/18/2008 - 04:50
These configs are a bit old and crusty , but they should give you an idea on how to set up async routing on the AUX ports. As Paolo says , performance is not brilliant, but it will work ... The chat scripts would likely need to be modified to suit your particular modems -
#####DIALING SIDE############
username PRIROUTER password SAMEPASSWORDS
chat-script modem "" "atdt\T" TIMEOUT 60 CONNECT \c
chat-script rstusr "" "at&fs0=1e0&r2&d2&c1&b1&h1&m4&k1q0" "OK"
interface Async1
ip address 192.168.10.2 255.255.255.0
encapsulation ppp
async default routing
async mode interactive
dialer in-band
dialer string 5553731
dialer-group 1
ppp authentication chap
ip route 0.0.0.0 0.0.0.0 Async1
dialer-list 1 protocol ip permit
line aux 0
modem InOut
script reset rstusr
transport input all
flowcontrol hardware
script dialer modem
######RECEIVING SIDE##############
Username RouterA password cisco
interface Async1
ip address 192.168.10.1 255.255.255.0
encapsulation ppp
async mode dedicated
dialer in-band
dialer-group 1
ip route 0.0.0.0 0.0.0.0 async1
line aux 0
modem InOut
script reset rstusr
transport input all
WabukiSensei Mon, 04/21/2008 - 20:21
Hi, Thanks for the tip. If I were dialing from a Laptop connected to a modem, would there be any differences in the configuration?
Thanks.
Correct Answer
pcameron Mon, 04/21/2008 - 20:33
WabukiSensei Sun, 05/11/2008 - 19:14
Thanks for the tip, guys. I've finally been able to get this run-down modem to work.
