frankzehrer Thu, 02/14/2008 - 03:32
  • Silver, 250 points or more
Hi Herve,
your ACS is configured for https requests.
Have a look into the ACS at:
- Administration Control
- Press the Button: Access Policy
Check the value in the Field: Secure Socket Layer Setup
So you have to change the integration option in the LMS from http https in the "AAA Mode Setup".
Hope that helps.
Good Luck,
Frank
rherve Thu, 02/14/2008 - 04:49
Thanks for your answer but it doesn't work.
The value Secure Socket Layer Setup is already checked.
If I check "Allow any TCP ports to be used for Administration HTTP Access" instead of restricted ports, it doesn't work.
Do you know if the ACS Release 3.3(1) Build 16 is supported by LMS ?
Does the ACS user need a another specific access to get this working ?
Thanks in advance for your ideas about this problem.
