02-14-2008 03:17 AM - edited 03-18-2019 08:28 PM
Hi all ,
As I have to provide a configuration for integrating VOIP and exchange 2007 UCM I'm looking for documentation,example and WP on this topic .
Can anyone help me with his experiences on building such solution ?
Thanks for the help
Stefano
02-15-2008 01:05 PM
Hi, if you are looking to integrate a Unity server with Exchange 2007 this can be done ONLY if you have Unity 5.x otherwise you'll have some trouble, if this is unity 5 and ex2007 this is a standard integration, nothing special, just make sure you install exchange 2003 tools on the unity server.
02-15-2008 01:42 PM
Hi ,
I don't know much aboout the unity product. Where can I find a WP on the building blocks I should integrate ?
As the customer has around 50 users I thought of using the unified comunication 500 series . Is that appropriate ?
thanks
02-16-2008 11:55 AM
hi,
these two links would be at help :
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/installation/guide/umexfo/5xcuigumefox.html
apart from that for sizing the unity server, refer
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/requirements/50cusysreq.html#wp515832
Rgds,magesh
