Outside Dial-tone in CM 4.2 not working
Feb 14th, 2008
  • Silver, 250 points or more
Suddenly when users press 9, phones are not providing outside dial-tone. All the route patterns are checked for "Provide Outside dial-tone"
Any tips on this?
Overall Rating: 3 (1 ratings)
davetucker Thu, 02/14/2008 - 04:27
  • Bronze, 100 points or more
Hi Rajesh,
This is most likely because Call Manager has more than one potential match.
If multiple route patterns exist with the same first digit, you must make sure that they are all checked to "Provide Outside Dial-Tone", common conflicts can are 9.@ and 999 (or 911 in the US).
Conflicts can also occur in any DN on the system whether is is a Line, Meet-Me number, CTI Route Point, VM Port etc... i.e. Number in the 9XXX range will interfere with secondary dial-tone for 9.@
Hope this helps, if so please rate!
Dave
Rajesh Revuru Thu, 02/14/2008 - 06:41
Dave:
Thanks for the information, i ran the route plan report, there are some directory number starting with 9000-9010
How can i fix this?
davetucker Thu, 02/14/2008 - 06:51
Rajesh,
The only way to fix this is to remove the conflict. You need to renumber the extensions that are in the 9XXX range into another spare range. Alternatively move to a 5 digit number plan and prefix with another digit i.e. 29XXX.
Hope this helps, if so please rate,
Dave
Jaime Valencia Thu, 02/14/2008 - 08:34
  • Cisco Employee,
  • Hall of Fame,
    2011
just as a side note that is explained in the SRND
Avoiding Overlap of Extension Dialing
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/4x/42dialpl.html#wp1043339
the thing with the dial tone is that since CUCM does digit analysis digit-by-digit and creates a 'potential matches' list only when ALL the DNs or patterns on that list have the checkbox for the secondary dial tone CUCM won't generate it. The only elements that have the checkbox are route patterns and translation patterns, so if you have a phone DN in there, until CUCM is sure that there is no chance you're going to dial it and kicks it out from potential matches you won't get the secondary dial tone
