change name on certificate
Feb 14th, 2008
I did my CCNA certification in july 2007. My name is RANA TAHIR RIZWAN but certificate received by me has RANA TAHIR T RIZWAN. I want to correct this mistake. Plz help me.
mheusing Fri, 02/15/2008 - 08:53
I would suggest to open a case with the Certification Online Support tool.
To access it follow the link http://ciscocert.custhelp.com and login or create a new account.
Once you are logged in click on the "Contact Support" answer listed. This will give you a new tab "Contact Us" (between "Instant Answers" and "My Cases & Profile").
Click on the Tab and open a case with your request details. You will be contacted shortly after that.
Hope this helps!
Regards, Martin
