brand new 2851 problem
Answered Question
Feb 14th, 2008
  • Purple, 4500 points or more
Got a brand new 2851 and it appears it has a problem when I try to do a write mem I get the following . any way around this or is time to RMA .
*Feb 14 15:13:37.543: %SYS-5-CONFIG_I: Configured from console by console
*Feb 14 15:13:39.463: NV: Invalid Pointer value(45911384) in private configuration structure
*Feb 14 15:13:39.503: NV: Invalid Pointer value(45911384) in private configuration structure
*Feb 14 15:13:39.503: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometry of nvram
Correct Answer by davetucker about 9 years 3 months ago
Hi Glen,
Had the same problem with a 3845 the other week.
Try the following
erase /all nvram:
This will erase the NVRAM, Re-Initialise the geometry and reset the pointer unlike the "erase nvram" command.
Hope this helps, if so please rate.
Dave
Overall Rating: 5 (1 ratings)
Correct Answer
davetucker Thu, 02/14/2008 - 07:38
  • Bronze, 100 points or more
Hi Glen,
Try the following
erase /all nvram:
Dave
glen.grant Thu, 02/14/2008 - 07:42
Dave you are the man , that fixed it . Thats what is great about this forum . Saved me the hassle of RMAing the device . Got to keep that one in the back of mind .
