Disable debugging in config
Feb 14th, 2008
Since upgrading firmware, on each boot the router automatically turns on debugging, and it has to be manually switched off using the "undebug all" command. How do I stop this from occuring?
Edison Ortiz Thu, 02/14/2008 - 11:28
  • Hall of Fame,
    Founding Member
That's odd. Post show version and show debug from that router prior disabling the behavior.
__
Edison.
damianmoran Thu, 02/14/2008 - 15:01
Thanks for the reply.
show version:
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(15)T3,
RELEASE SOFTWARE (fc1)
show debug:
dot11:
dot11 Syslog debugging is on
Edison Ortiz Thu, 02/14/2008 - 15:33
  • Hall of Fame,
    Founding Member
CSCsi60925 Bug Details
dot11 syslog debug enabled by default
Symptom:
'show debug' shows that syslog debug messages are enabled by default.
Conditions:
On router boot up, dot11 syslog debug enabled.
Workaround:
None.
_____________
Status
Fixed
Severity
Last Modified
In Last 7 Days
Product
Cisco IOS software
Technology
1st Found-In
12.4(13.9)PI6a
12.4(13.13)T1
Known Affected Versions
Fixed-In
12.4(18.2)T
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=%20CSCsi60925
HTH,
__
Edison.
