LMS 2.6 Archive Problem
Feb 14th, 2008
Hey all
We have a problem with LMS 2.6.
Within RME/Archive Management within "partial successful, we have many devices with the message "CM0020: Error creating archive" for either the running config or the startup config.
When checking the Credentials, these are okay.
If we delete the device and reinsert it all information is okay.
Does anyone what the cause of this message adn what we can doe about it( We couldn't find it in the manuals)
Joe Clarke Thu, 02/14/2008 - 10:52
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Seeing the dcmaservice.log for one of the device producing the CM0002 error might be helpful. Typically, this problem is caused by an incorrect system identity user. However, if removing and re-adding the devices corrects it, there may be some file system problems. Unfortunately, the workaround in that case would be to remove and re-add the devices.
