creating CISCO2801-CCME/K9 bundle
Feb 14th, 2008
Is it possible to create this bundle with an existing 2801 router?
if so please explain.
mameiers Thu, 02/14/2008 - 14:38
I am not really sure what you mean by create a bundle on an exisiting 2801 router.
You can certainly add the additional pieces to your 2801 that would normally come with a bundled router, but there is no "all-in-one bundle an exisiting router" part number.
gl8016nw7 Thu, 02/14/2008 - 18:31
this is what cisco sells as a bundle.
Cisco 2801 Voice Bundle with IOS SP Services, PVDM2-8, FL-CCME (24 users), 64 MB Flash/256 MB DRAM
i have the hardware to put this together with the software but dont understand how to put all the nessessary files on the router to make the CCME work properly.
mameiers Thu, 02/14/2008 - 18:38
As long as you are correctly licensed for Cisco Unified Communications Manager Express you can download the CUCME files from CCO.
A tar archive contains the basic files you need for Cisco Unified CME. Be sure to download the correct version for the Cisco IOS software release that is running on your router. The basic tar archive generally also contains the phone firmware files that you require, although you may occasionally need to download individual phone firmware files.
This link should help you get the files correctly installed on your router.
