Clear unknown protocol drops
Feb 14th, 2008
If I do clear counters or clear counters fa0/0...it clears every stat except unknown protocol drops...(see below)...how do I clear that stat?
FastEthernet0/0 is up, line protocol is up
Hardware is MV96340 Ethernet, address is 001a.2f52.49f0 (bia 001a.2f52.49f0)
Description: ;;SUBSCRIBER GATEWAY;;MR;L3 FE;
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:07, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:00:42
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 90000 bits/sec, 63 packets/sec
5 minute output rate 241000 bits/sec, 39 packets/sec
1346 packets input, 353605 bytes
Received 240 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
854 packets output, 274919 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
4415151 unknown protocol drops
0 lost carrier, 0 no carrier
paolo bevilacqua Thu, 02/14/2008 - 15:17
  • Hall of Fame,
    Founding Member
Woops, seems like you've met one of these things that cisco "forget" to handle right, and only a reload can clear.
